new socket
pipme said:
Regional Co-ordination Unit ? ... Downriver from incomer or Cu .. Only Edward knows ... but then again ???
P
Downriver from incomer.
Eddie M said:
RCU??? what am I like?? sorry, RCD !! Yes it will stop me from getting a probably fatal bolt off the fuse box, that is if it works (which it seems to) but that is not the issue, if it doesn't work then accepted, I'm toast
As you will be if you're the link that completes a live-neutral circuit, for which hazard an RCD provides no protection at all.
And are you sure about the downstream bit? How can that protect anything, other than, say, one socket circuit?
Eddie M said:
P
Doh - this came in while I was typing my previous reply....
So when you said the the FB was protected by a downstream RCD, you meant upstream....
ban-all-sheds said:
Eddie M said:
P
Down, up, I don't know !! Between the meter and the CU.
And even better news, the existing shambles is all going next week just accepted a quote, the original wiring is fortunately in good nick, basically requires a CU swap out, incorporating the various original CU's and RCD into one unit. Split load considerations and final config to be completed, but around the £300 - £350 mark, quite happy really, I don't like working on that old CU.
BTW, I'm sorry for hijacking the origina;l post.
