Digital sources sound hollow, and precise, wheras analogue is more full, rounder, fuller sounds.
And the same effect can be achieved with a digital recording.
A digital TV picture is unnatural, a digital picture gets cut off at the slightest interference
I don't see how it looks unnatural. And no, it does not get 'cut off' at the slightest interference..
Does a record fail if it's scratched? NO
Does a CD fail if it's scratched YES
Incorrect on both accounts. Both vinyls and CDs display similar behaviour if scratched: You lose any data in the location of the scratch.
Was Betamax better than VHS, YES
Actually, you're right there.
Can you get a picture in bad weather via Sky? NO
Can you get a picture in bad weather via an antenna? YES
Can you get a picture on Digital TV via an antenna? NO
Can you get a picture on normal TV via an antenna? YES
Yes you can get Sky in bad weather. Yes you can get Freeview in bad weather. Whether satellite or terrestrial, if you have it set up properly, only the most severe weather should affect it. We do not get such weather in this country often.
Do LCD TV's work for longer than 5 years? NO
Do Plasma TV's work for longer than 5 years? NO
Both can easily last that long. You make it sound as if every single TV dies when it's five years old..
Would you prefer to watch a TV picture of poor quality, or a TV picture saying 'no signal being received?'
I'll continue to watch my good quality, reliable Freeview, and soon Freeview HD, from a properly installed antenna, no matter the weather. When there's actually something on television which is worth watching, of course. The rest of the time I spend in front of such a device will be spent watching the HD images your CRT is incapable of displaying.
