We are having our small detached house enlarged by about 50% to a total internal volume of roughly 250 cu m. It is 1956 brick built and apart from there being no CW insulation in the original walls (yet) the planned insulation will be about the current standard.
We are now researching a water heating system within our budget. Mains flow rate is 21 l.p.m. bucket test.
There will be a downstairs shower room and an upstairs shower/bath and separate en suite, and conventional water filled radiators.
We already have an Intergas compact 24 OV only 2 years old and are happy to stay with an open vent gravity system if needed. The header tank is in the loft and its base is 2550mm above 1st floor level. There is room to raise it possibly by 900mm before it starts to get close to the rafters.
We want to avoid fluctuating temperatures in the showers. There are usually only two of us but we expect problems with washing machines and kitchen taps all fighting for water.
We don’t feel easy about Megaflows but like the idea of a thermal store with a plate exchanger. We are in a hard water area but understand that a good installation can help reduce scale formation by keeping temperatures to a minimum.
We understand that using the thermal store for central heating water as well could be a good option.
We have heard of some models that have a choice of plumbing points for the optimum cold return.
In the worst case if our plumber ends up advising against a thermal store due to either cost, complication etc, we are not sure of our options if we stay with a gravity fed simple HWC
It seems the choice is between low pressure mixers with a cold supply from the same header as the hot, or pumps, and a thermostatic mixer at the shower end.
We wouldn’t want electric, nor a combi boiler, nor a megaflow as mentioned.
Would there be enough power in the showers to prevent them running hot or cold whenever a tap is turned?
