Hi
Just had a new downstairs toilet fitted as part of an extension. The toilet flushes OK but just after it has flushed it makes a kind of popping noise, and the water level is low in the bottom of the pan.
We've lifted the outside manhole cover and the drain appears to be clear, however the builders may have let the odd bit of rubble drop down the drain that leads from the toilet. Could it be blocked or is it a venting problem ? And why the weird 'pop' ?
Also, I think, but can't be dead certain, that the water level in the existing toilet upstairs is also a little lower.
