New unvented tank on Bore hole supply
5 Jan 2012
Devon
I have a bore hole / spring water supply from a water treatment plant delivering 4.5bar pressure regulated to 2.5 bar to the house. I am looing to replace an old thermal copper heat store system with an unvented tank. There is a vast cost difference between megaflow systems recommended and others. Do you have a recommendation for system. My reason for changing is the heat store delivery flow is restricted and if we run a bath and shower at the same time the shower stops. many thanks
I`m assuming you mean you have a vented hot water tank. A pump on the hot water maybe a cheaper option.
Sounds to me like the problem is with your borehole pump not keeping up with demand if the water actually stops running from the shower when the bath is run. A thermal store should be able to provide as much hot water as an unvented hot water cylinder.
