B
BigBurner
The Broag 35C is highly rated using the same parts as a Vaillant
really? which parts are they then?
Heat exchanger, pumps, I think gas valve. The Broag is far better specced too.
Just to add another 2 pence.
Personally if you see yourself needing high demand for DHW i would keep your existing system and replace with a new condensing boiler. You then have the option of replacing the cylinder for a fast recovery type or if demand's are high and building control permits you could upgrade to an unvented cylinder, although from what you have said i would think this is OTT.
My opinion is that to get the most out of a high flow combi you will need to have top cold water main flow, bigger gas supply and cold main to boiler and you will probably not see much performance increase from a well installed vented cylinder which you already have!
the same yes, not exactly but I'll give you that, seeing as 80% of manufacturers use the same design thats nothing special.Heat exchanger
nopepumps
you think wrongI think gas valve
Thanks for your reply Sambotc..My opinion is that to get the most out of a high flow combi you will need to have top cold water main flow, bigger gas supply and cold main to boiler and you will probably not see much performance increase from a well installed vented cylinder which you already have!
Sam
Got to say I am grateful to all you great people for taking the time to reply.... in fact keep them coming. regards The Dog
Another set of questions I'm afraid . What is regarded as "top quality water main flow?.. How much does a "hi flow combi" require? How do you measure it?.. I know for a fact that my mains water tap (where it enters the house) is barely turned a quarter turn because the pressure is too fierce for the cold water kitchen tap otherwise..
