Aldi have sold some large workshop tools of late - including a thicknesser, but I've not seen the same in Lidl. Screwfix sell the same brand (Scheppach) but at much higher prices.but I would avoid aldi tools and buy lidl just from experience.
I suppose I'm not a typical DIYer.Get all your stuff cheap at aldi, and get up and running instead of pondering.
No good dreaming over tools that you may not even be able to use properly.
Why does any DIYer need a planner thicknesser for instance? Yes I know what it does.
Presumably you are not then burning the wood, but using it to make stuff?A lot of my planer thicknesser is used on salvaged firewood.
Pondering at the moment as I won’t have a workshop for several months - so I have time to deliberate, change my mind, change it back again to hopefully reach a sensible conclusion.Get all your stuff cheap at aldi, and get up and running instead of pondering.
Have you ever heard the phrase “a bad workman always blames his tools”?Most of my larger workshop tools are cheap and I've not got any quality issues with using them.
You appear to be saying that you are a bad workman.Have you ever heard the phrase “a bad workman always blames his tools”?
Well, all my tools are crap.
Not a chance! I pride myself on quality workmanship. If it won’t go in as a screw, it’s going in as a nail.You appear to be saying that you are a bad workman.
The saw mill sells the outside bits of the trees, after squaring off the trees, and other waste, that it can't use for its customer's orders, or it doesn't come up to customers' expectations, etc., as firewood. They aren't too picky about what they throw away.If to make stuff, then yes thats a use for it, but then again if you are buying the scrap wood that the saw mills don't want or can't use, then it would take some knowledge and experience in selecting which bits would be useful to plane down to useable timber for particular jobs - which is quite niche and specialist for mere DIY use.
Don't be too hard on your own abilities.Have you ever heard the phrase “a bad workman always blames his tools”?
