just read my post, were says "ALL flooring" i mean the 18-25mm ply mate not ur exsisting floor..oops![]()
opps a daisys
As you can see, I was intending to follow the overboarding rather than replacing option.Wall and floor tiling basics said:If you have floorboards or chipboard down, no matter how level and flat they are, you still need to overboard them with WBP (exterior grade) plywood. ..... For over-boarding you need 12mm thick ply and screw it down every 200mm all over the face of the board. Use 25mm screws if you have 18mm floorboards and 30mm screws if you have 22mm floorboards ..... If you remove the floorboards to replace with ply then use 25mm ply.
Thanks again, guys. You're not telling me what I wan't to hear, but best I hear it before I screw up.![]()
I'm just wondering why the advice I'm getting now differs from the sticky that I've based my assumptions on:
If this really won't do it sounds like I'll have to get a professional in. Either that or follow my original plan but with some added Ditra and hope for the best.
