hi
who thought the world of screws and drilling two simple holes will be so confusing to me!
complete newbie here needing help with fixting something to wall.
bought a wood coat hanger (weighs about 4-5 kg). seller said he will include wall fixings but none included. so i am now in need to find some screws to fix this to a brick wall.
the wood material of coat hanger is about 1 inch thick, so i was thinking of getting 2.5 inch long screws.
i had couple of old screws which are shorter but i inserted them into the holes within hanger and i think i need 8mm screws. i had few questions if someone can help!
on screws:
1) can i buy screws in any smaller amount than 50/100 packs anywhere?
2) will 2.5 inch screw good enough?
3) where can i buy 2.5 inch screw? i had a look on tool station but i couldnt find any 6mm screws which are 2.5 inch long?
4) do i need any particular type of screw? when i search for masonry screw it comes up with very expensive screws? dont think i need any special screws?
4) how about wall plug? what size?
on drilling hole:
1) for a 8 mm screw what size drill bit do i use? 8mm is the screw head dia if i understand it so not sure if i need 5 or 6 mm drill bit?
i have just bought a bosch SDS drill (PBH 2000).
ta
on screws:
on drilling hole:
ta
