Fischer are German and have consistently played their own game for years. Screwfix are still selling them, though (and in doing do making liars out of very joiner in the country....... OK maybe a tad overstated)
So, finally got to it. As it appeared I was way overoptimistic of the kind of wall that was. This an internal wall and seems to be some kind of breeze block or similar. Normal plugs didn't work, tried Fischer SX (high performance) plugs, and although it is relatively snug in there and does not rotate when fastening the screw, the whole thing is not strong at all. When screwing in there are some crackling sounds and the thing will not take any weight at all with small stone chips from the block coming off loose. Really frustrating.
I've been thinking of trying something like gripfill with the plug, or may be go for the chemical fixing with the resin. But the hole ended up enlarged of course (10mm or so). I've been also thinking of trying to put in a wooden dowel with some glue, or failing all of that go for some wooden panel attached in several places and screwing into that.
Any further advice?
I obviously want to end up with a fixing where I won't be worrying all the time that the guitar will fall down and break.
