Hi all,
I have just put together, but not wired up, two new storage heaters in an outside building. I will be getting an electrician to do the work, but I would like to know my options.
The meter in the house has a day and night reading, but everything we use in the house at night is on a timer as we don't have, nor need, an economy 7 circuit in the house.
In the outside building the existing cable runs into the consumer unit and provides two rings and lighting etc. If the two 3.4K storage heaters are on a separate ring is there a timing device that can be fitted to the consumer unit to decide when power was drawn or does a timer have to be fitted to each socket? Running a second cable outside would be horrendous as they didn't allow enough room!!
I hope that I've given enough detail.
Thanks,
Neil
Thanks,
Neil
