I am trying to get used to my NSH, 2 questions someone maybe able to answer.
If the heaters heat up at night and I do not use the boost button and there is still some heat within the brick/blocks, I assume the next night it will use less electricity to keep the bricks/blocks at a certain temperature, is that correct?
I have a digital electricity meter outside the property.
There are controls to adjust the water heating times but no controls to adjust the timing the heaters heat up. So when the clocks go back and forward do the heaters automatically adjust and heat up during the cheaper off peak tariff?
