Nissan navara revs problem
dpf removal is becoming more popular now, the management side is mapped out of the system and the dpf innards are removed from the exhaust.
Supposed to be around £600 for the service but cant comment on if its reached nissans yet
Well 2 days of luxury. Now it's back to 22mpg. And jumping all over hop. High revs etc.... Any help?????
That's a pity.
On the link you gave they mentioned that you will get a flash code to read the fault codes? See can you make sense of it. 3 flashes = 3 then space then 4 flashes = 4 ...... 34 etc. Not the easiest thing in the world to do.
It looks very like it ain't burning off the DPF and going into limp, does it seam like that to drive?
I got ten flashes fast then ten slow repeated. I wasn't really takin much notice. Just wanted to reset it.
It's not doing limp mode at all. Just revving high into 5k+ rpm when cruising at 20-30 mph and then jumping into gear
