OK,it's a Turbomax 242E,i've been looking at online spares places and i've got myself a little confused!! The diverter valve is the bigish metal thing at the bottom right?? The part that i thought was faulty is a black valve type thing with a RED microswitch on it-the lever inside this moves straight away when the CH is turned on and the bolier lights,DHW can then be drawn at any rate.If the CH is off this lever will only move and trip the microswitch if the water is turned on at a high flow rate(well MAX now!)soooo,is the faulty part the bit with the micro switch(i think they call it the pressure/flow switch(about £20) or this diverter valve(which is ££££££! about £100) I don't want to spend £100 an a valve that won't fix the problem!! Thanks for any help guy's.
