Hi Again RR,
Have a look at the cable on your brother's computer (the end that goes into the modem) and see how many wires are going into it. Check yours and see if they are the same - I have seen cables with 2 wires, 4 wires and VERY occasionally 3 wires
Having saying this, do we know if the cable that came with the modem (and computer) was the same one the previous owner was using.
I am reluctant at this stage to start saying 'swap modems' with your computer as his one tries to dial out, so that would suggest that it is on the right 'com port', software is installed ok, etc.
Even if his cable works in your computer, it doesn't mean that it is the right cable for his modem. Also, unplug his cable and look into the socket - check that none of the little copper 'strips' are bent or broken.
Do you have a little 'back-street' computer shop near you? It might be worth taking his computer down there. I really don't think there is much wrong here, so I guess the costs wouldn't be very high and it might be the fastest solution for you
