Hi. This morning we woke up to a frosty morning and quickly went to look at our new extension roof. Our old lean to of an extension had no insulation and so having a new 'solid' roof was, to us, quite exciting.
All around we say frost on our neighbors roof, but not ours. When I approached our builder about this, he said we should not have frost on our roof. I fairly certain this is not true. what I do know is that he put celotex in between the joists and then over the joist to regulation - approved by building control and signed off.
It is a pitched roof to 13 percent - is it possible that some tiles do not frost?
I can feel a draft coming through the roof from where our down-lighters have not yet been placed as we are to do another coat of paint. should there be air coming between the insulation and the ceiling? He mentioned needing to put a sealant on the outside, which may explain the draft. But still unsure about the lack of frost. Thanks for any help on this. our builder has tried to cut corners a couple of times so want to check.
