The OP has described the access, not me, and has said no pipelines but other deliveries are OK.
No we don't have vehicular access to the property.
And like I said you're talking rubbish.
So that means you'd have to lug the oil tank across a field then t***pot.
And you don't need to buy 2 tons worth of solid fuel so you're also talking rubbish.....
The only difference is I'm not interested in seeing you do it on Youtube.
So you propose oil then knock other peoples suggestions
You seem to have difficulty understanding NO PIPELINES ALLOWED
No , it makes it impossible if this statement below that the OP has written is indeed correct.Which makes solid fuel difficult but feasible
Why would he say this ? Is he a squatter and the owner has blocked the right of way to the property ?No we don't have vehicular access to the property.
I shall repeat again. If you can deliver the solid fuel then you can deliver the oil.We have rights of access for normal use, including deliveries
The GSHP pipes could be laid in our land.
Except he says you can't use a pipeline, you can carry pellets however undesirable
We have rights of access for normal use, including deliveries, but are not allowed to lay a pipe across the neighbour's land, even if only temporary.
OP's comments above gave me a bit of a clue.
