may i add if your not sure don't try it
Probably not.flutterbye said:Could it be fixed by draining down the system again, opening up the inlet/outlet pipes to the coil and flushing them with a hose?
flutterbye said:Or how about bypassing emersion stat so outer water boils?
flutterbye said:Is that the connection that is about half way up the cylinder, comes from the boiler directly and is hot? I've tried opening it but only get water - no trapped air.
flutterbye said:If it might fix itself how long do you think I should wait before getting a plumber in?
I already tried (to no avail) the cold return feed from the cylinder.
Thanks for the help you've given me so far btw.
Hm, that's not very specific. Which method did you use?flutterbye said:I solved it in the end by boiling the water as previously described.
OK. Good. For one alarming moment I thought you'd tried the ill-advised immersion boiling trick.flutterbye said:I used the technique described by Bab earlier in this thread by boiling the water in the coil.
Er, I didn't say that. It went like this:You still haven't said why you think blasting some mains pressure water directly into the coil wouldn't have solved it?
...and my reason was that your plan was to add yet more air to the system and then flush out a blockage that didn't exist.I said:Probably not.You said:Could it be fixed by draining down the system again, opening up the inlet/outlet pipes to the coil and flushing them with a hose?
