Hi there, I have recently experienced a problem with my boilermate2, when i turn on the hot tap i get 2 seconds of hot water then it runs tepid . I have checked the heating to see if there is any hot water and that seems to be working fine.It also makes a buzzing noise when the central heating is on, not all the time just at intermittent times and seems to be coming from the central panel. I have tried to contact various heating engineers but no1 seems to want to look at it or they change obscene amounts to come and look at it. Does anyone know a possible solution to this problem? Or do you know of an engineer that doesn't charge £75 an hour in the burnley area thanks in advance Martin.
