Hi folks,
Having a bit of a mare. I emptied our hot water tank in order to replace one of the immersion heaters yesterday, that was the easy bit!
Since I have turned the water supply taps back on I've had no water coming through any of the hot waters taps. I know that the immersion tank started to fill when I turned the water back on as I could hear the water rushing back in. But I'm not sure if it has filled all the way up. I have also checked the supply tank in the loft to make sure that was full - and it is.
I have checked several times I have definitely tuned the supply taps that I tuned off. I have not yet tuned on the immersion heaters as I was worried that if the tank hasn't filled they might burn out (so not sure if this could be causing the problem?)
Any advice would be very gratefully received!
Many thanks,
anthony
Many thanks,
anthony
