Hi..
Hope somebody can help. I have a GlowWorm 35 F fuelsaver. It's an old conventional boiler running in a low pressure system with a cold water tank. I've recently had the fan changed on the boiler and had it serviced. All was working fine initially and then I began hearing some intermittent banging coming from the pipes. I ignored it at first and then I noticed that whenever the thermostat in the hall was set to below room temperature the banging would start up so I kept the thermostat setting above room temperature.
This kept the problem at bay but I also noticed the banging occured whenever I left the Hot water switch on but turned the Heating switch off at the switchmaster. Now today I've noticed that in addition to the banging problem there is only luke warm water coming out of the hot tap, although the boiler is coming on as usual, radiators are working fine and the pipes to the tank are hot.
Could anyone advise as to what the problem could be and if there is anything I can do to further diagnose it?
Thanks in advance..
Sunny
Thanks in advance..
Sunny
