22mm Gate Valve from loft tank serving the base of the cylinder
Which do you think would be the problem valve?
I which case, it looks like you have found the problem. Faulty cylinder statif cylinder stat temperature increased boiler fires
If he has water coming from the taps, where is this acually coming from? Can't be a faulty service valve!So you have cold water coming from the hot taps, yes.
Is the draw off at the top of the cylinder hot?
