Hi all.
I have a worcester 24i RSF boiler. One of the valves on my radiator was leaking so i had to drain the system.
System drained then i blanked off the valve until i could get a plumber in (next week). I repressurise the system by opening the cold inlet valve. Pressurise to 1.2Bar. Now the boiler wont ignite and i hence dont get any hot water or central heating.
I tried bleeding all the radiators, still the same. Admittidly, 2 of the bleed valves were broken so i couldnt bleed them.
Is this an airlock problem in the system? Should i pressurise to say 2.5bar to expell the air from the actual boiler?
