No hot water pressure - Range Tribune
23 Jan 2011
Cambridgeshire
Im after a bit of advise please...there seems to be an issue with the hot water pressure in my house, i have a Range Tribune HE unvented system (The house is about 5 years old and ive lived here for 2 years now).
At every sink and shower (over 3 floors) the hot water seems to run out at a really slow rate even with the tap on full and over the last few days it seems to have got worse so much that the shower now just trickles out. The cold water doesn't seem to be a problem anywhere in the house.
The pressure gage on the cylinder is at 2 bar (the max it suggests). Ive bled the radiators to see if that was having any issue but that all seems fine, there isn't any problems with the heating side of things.
Does anyone have any idea what could be causing the low water pressure? Ive looked in the manual and the only thing is states is if there is no hot water flow then the strainer in the pressure reducing valve may be blocked and should be cleaned. Any idea where that is exactly and what the process is for cleaning it?
Appreciate your help!
If its the strainer then the pressure will seriously fall from 2 bar when you turn on a hot water tap.
Since anyone working on an unvented cylinder needs to hold the appropriate certificate then I cannot give you DIY advice on doing repairs on an open forum.
Are you sure the pressure is the cylinder pressure and not a heating system pressure?
Tony
Hi Tony,
The gage is the one at the water cylinder. When we need to top up the system this is the gage we use to determine its levels. This doesn't seem to move when we are using the hot water and still having the problems so if you do not think its the strainer do you have any other ideas what it may be, or things we could try?
Thanks again
Since you done seem to be aware that the gauge is the heating system pressure then I would not advise you to attempt any work on your system.
It might be the strainer but it could be other things and needs a competent qualified oerson to check its properly installed and diagnose the fault.
Tony
