top back on.
Yes, boiler does fire up with just HW on....
feel bothsides of the valve to rads and hw what side is getting hot ?
and feel the return out of bottom of cylinder what is that ?
that tells me the valve is faulty in the bottom is like a rubber ball that moves side to side, and they wear.
you have hw only on so you shouldn't be getting hot rads. valves passing water.
as for your hw cylinder the top pipe is hot the bottom is cold i would say you have an airlock in cylinder coil.
yes the motorised valve faulty. letting by to rads on hw only.
as for turning high to low should make no difference.
to get the air out of coil slacken the nut on the cylinder side of the mot valve afew turns.
place a tower and abowl under it, that will release some water but should release any air in coil.
i think all yours needs changing as your rads get hot on hw only.
that tells new it's not shutting fully.
start about £45 up depending on model.
if changing the lot it's a drain down.
i would take it off and check first it may be just muck jamming it from shutting if it's old, it don't take much gap to let hot water pass.
could save you a few bob.
yes the brass bit as well thats where the ball is and they can break up.
