I have a thermal store system about ten years old. About two weeks ago the hot water went luke warm & the flow was poor. The central heating system is ok. The hot water is derived from mains pressure which is reduced by a diaphragm reducer, then double check valve, then through a coil in the cylinder which is heated by the cylinder hot water. This then is mixed in a blending valve to the taps and shower. The pump and boiler supply is working ok.
I suspected the blending valve as the hot pipe out before the blender was considerably hotter than the pipe to the outlets.I have changed this but no difference. The hot water taps are mostly now cold although you get a short burst of luke warm water occasionaly. Also the water seems to be pulsing.
There is a thermostat on the cylinder for the water temperature which is set between 60 & 70C
Can anyone can help me please?
