Hi Folks,
Had a little accident involving a screw going through a hot water pipe. The system was drained down and the leak fixed but now the system will not heat any water.
Its an indirect fed system with the boiler feeding the water and central heating. The boiler is heating water and the central heating works but the water tank is not being heated. The pipe work up to the hot water tank is getting hot but the outlet is stone cold and so is the contents. Its like there is a blockage in the cold water return.
Does any of that make sense?
Any help/advice would be greatly appreciated.
J
J
