It's not those ones then!bath and basin taps all single.
It would be handy if the cold (and/or hot) supply to each of those taps had its own individual isolating valve, then you could test the effect of turning off one at a time.sink tap in the kitchen is one of the single lever mixer taps feed from cold mains as is the tap in downstairs wc.
If not, I would fit valves in order to eliminate them, but they're my odds-on favourite at the moment. If a cartridge has an internal fault then it could allow cold to leach into the hot side, back up the supply, into the cylinder and up the cold feed to the cistern. There are people who believe that this is impossible, but it happens, and I've seen it many times, and it's usually on shower valves with the same type of lever-operated cartridge as your basin and sink monoblocs.
