Hi again
ShyTalkz said wouldn't work if no triangular loading pattern above.
There's a bedroom window above and if you look at the picture link I've added I've highlighted a crach going up in a diagonal line( the crack is a brick below the red line if you look closely and only on the right side)
Does this indicate a triangular load where the force above is pushing the bricks to the side down to the edge of the window below, forcing a crack to appear in this way?
Having seen this picture what lintel would be advised to be installed or is the advice the same as before.
http://i176.photobucket.com/albums/w182/johnsmoker/windowOUTSIDE.jpg
Very amusing squabble by the way
