Thanks Grinch. I have looked at the old frame that was replaced and indeed it does have holes where I would expect to see them. What's the point of weep holes on the exterior if the moisture cannot get there?
As the frame has been fitted and rendered in, the only option is to add them myself. I cant make a worse job than the fabricator already has.
I would not recommend this supplier whatsoever.
