Tie up the float valve...
Get a long hose pipe and run it outside well away from patio/drive etc
Induce flow in the hose either by putting the top end over the float valve outlet and pushing down on the hose or by pouring a jug of water into a funnel in the hose end...
When the water is flowing use the end to hoover out all the muck in the header tank... adding more water if necessary to loosen all the much.
There simply is too much to lose pulling all that muck [carp!] into boiler, pump etc
