hi all,
I have recently had a new Combi boiler installed a ideal logic 30KW
Everything is ok with the exception of the three radiator’s upstairs (Landing, back bedroom and front bedroom)
When the heating is on I can hear a noise, which sounds like running water / the boiler noise coming through the radiators, this noise is the same when the heating is off but we use the hot water in the house.
I have done the following to try and get rid of the noise
1. Bleed all rads
2. Drained the system and refilled up and bleed
3. Messed around with lock shield values
4. Removed TrV heads to make sure it’s not this
5. All rads and TRV’s were replaced about 2 years ago
6. Turned pump speed down to 70% this is as low as it will go.
I just find it strange how three rads are making this sounds when the rest aren’t, below is what we have in the house.
3nr towel rads
4nr double rads
5nr single rads
Any help is greatly appreciated
Martin
1. Bleed all rads
3nr towel rads
4nr double rads
5nr single rads
Martin
