OK, tried boiler pump on setting 3, pretty much same effect as when going from 1 to 2, just reduces the noise a little, but certainly doesn't get rid of it. As expected, it dropped the temp. diff down to about 10 deg C. But boiler still noisy.....
The 22mm lockshield valves are installed just above the boiler as there are no valves on the boiler. Without these I would have to drain the store to do any work on the boiler, hence their installation. I'm sure they are full bore. But these have always been on the boiler from the start, when it didn't make a noise....
I think you're idea about testing with cover off is the next step. Must admit to a little apprehension with this one though !
I think you may have misunerstood one of my previous posts - the boiler doesn't cycle, it's the store that starts and stops the boiler. Only if I set the boiler burner too high ( not thermostat ) does it cause the boiler to cut out. I always have the boiler set to max on the stat., and then let the store keep the boiler running until it is up to temperature, at which point it shuts down the boiler. So from the store requesting heat it is just one long burn until it is satisfied, at which point it shuts down the boiler. No cycling.
This is intentional. General plan is that the mixer keeps the temperature down as low as possible until the store is nearly full, then it starts to increase. Stat on store is set such that it'll cut the boiler out before the boiler gets anywhere near it's own max. setting. Hence no cycling of the boiler. Boiler stat is 85 deg C according to manufacturer.
The boiler manufacturer states a temp. diff. of 20 as ideal, so anything less can't be an issue.
Maybe I should send you an mp3 of the noise.....
Not sure if I'll have much time to play today, family visiting so not a good time to be playing with the heating !
Andy
Andy
