I dont get this, why not feed the big things will the constant supply
One reason would be that the "constant supply" may not be as constant in flow and/or temperature as the sales brochure claim them to be.
A cylinder will give better supply of hot water and boiler need not be high output so at times existing gas line that supplied gas to earlier model could be sufficient ( needs prior check)I dont get this, why not feed the big things will the constant supply and the small things with a small cylinder?
Can assure you the delivery and temperature are stable unless other taps run
A reduction in pressure in the cold water supply to the house can de-stabilise the temperature and/or flow of the delivery.
thanks I’ll do that
They aren’t bad when running. It’s the spaceship whooorp noise they make when they initially fire that annoys most people…
Not wanting to hijack the thread, but what model is the noisy one? Looking at Intergas to replace existing boiler, and noise may be an issue.
Thanks. That will be useful. Unfortunately looks like ECO RF is only available as a combiThe newer Xtreme and Xclusive models are noisier than the HRE. If you want a really quiet boiler the ECO RF is the one to go for
Thanks good to know. And when the time comes you don't appear to be that far away.
Because the flow rate is much lower through the combi than through the cylinderI dont get this, why not feed the big things will the constant supply and the small things with a small cylinder?
Yes…but the flow from the combi is more than adequate for a shower.. no? Bare in mind nothing else would be connected.Because the flow rate is much lower through the combi than through the cylinder
Yes, the combi will happily run one good shower.hope it’s fine for a shower and some simultaneous tap usage..
