If I can jump in on this thread, I have kitchen/diner part of which is an extension. It's approx 6 x 4mtrs, the extension part (4x3) has three outside walls, double glazed French doors and a DG window, the old part has just one outside wall. The builder assured me the room would hardly need any heating as the insulation was so good and just relocated the existing rad which is a single 160 x60cm. The room is so cold so I've resorted to topping up the heat with an electric heater. What size rad would I need to heat this room to a comfortable level? I did use an online calculator but bearing in mind what others have said about them not being very accurate, I thought I'd ask you experts.
