nut (not edible) in a pipe
would this work?[/img]
Why not take a scrap of brass or steel , file it round so its a snug fit in your pipe, drill and tap a hole in the center to suit your bolt then drill a ring of say six smaller holes around the central one to allow water to flow.
Brush some solder paste around the disc and inside the tube, tap the disc into position and then heat from outside to melt the solder.
I would knock something up on the lathe & mill but the above should work OK with handtools and a drill.
Jason
Jason b, its a very nice idea, but i can not do that with hand tools, and i dont have a lathe.
BUT, vaguely based on that idea, i have solved the problem. so a big thanks to all.
For those that want to know, i did the following:
MK1
Drill 4 holes paralell to each other, but both on the same plane. insert a brass bolt through each hole on one side, and bolt exits at hole directly opposite it.
Looking down the pipe you see 2 bolts side by side. place nut with bolt on "bridge" of the first 2 bolts, solder nut in position.
undo bolt securing nut on bridge. Er, undo bolt securing nut on bridge, can't undo bolt :cry:
heat vertical bolt to remove nut and bolt
excees solder has run down bolt soldering nut to it.
re solder new nut on bridge, nut falls off bridge down pipe Damn!
give up
MK2
Get 15mm copper pipe, solder on "stop end" drill hole in stop end tap stop end to bolt diameter.
Get 22mm pipe drill 3 holes in side at aprox 120 degrees apart.
tap holes for bolts
screw bolt in each hole
drop 15mm pipe into 22 mm pipe, stop end sits on 3 bolts :)
tighten bolts
screw another bolt with a large disc into stop end
connect to pump and test
nothing happens
undo central bolt with disk
get soaked
water going wrong way (it is following schamfered edge of disc)
remove bolt turn disc up other way
re-test :)
well it works, but not as well as i had hopped, but to complete the project i need to make 3 more
breezer
I did its for a spray ,DOH ......but what is it spraying water ,paint , beer ,lol..lol...lol...lol
as all liquids arent the same ...teehee
no, water and its finished (but doesn't work as well as i had hopped)
breezer
all that wasted energy/effort , an dont you feel a fool now ... ?
Maxxy
beer an failed.... :(
I think he would be Hailed as a "New Messiah, Oh Breezer !"
if the nut stopped more gas into the pint ..an more beer ....
but alas he failed .... miserable ..."breezer=loser *
the ..."Hard Lucks" will resound from the roof tops ...
paedos an shifty immigrants love breezer as the loser /sad guy King..
His mother/father try to get him adopted ...
flush of bad stories about his bad prowess in bed by bimbos follow ..
I catch up with breezer on beachy head cliffs ...
an ask him what went wrong with the wonderful beer invention ...
breezer , beer ? it was for water..................lol
Breezer wasnt ever seen again ... an the World carried on ..lol
couldn't you use some kind of "yorkshire" fitting with it's own ring of solder within?
i think i might be a bit late on this one. :rolleyes:
thanks for the suggestion, but i needed a gap to allow water to flow, its all finished and working now.
oh, if any one wants to see it there is a picture here
your had an self respect an killed yourself .
without your screw in pipe method , lol
btw Im sure old Saddam , is chuckling if he says DEATH BY GAS .....but administereded (sp?)by breezer... .lol
breezer
old lad ...my posts above were in jest , hope you werent offended , ?
