- Joined
- 16 May 2009
- Messages
- 6
- Reaction score
- 0
- Country
I've been in my 1970's house for 5 years and the heatings never been great but the hot water taps are ok.
I often have to bleed the rads and the pump is quite noisy. I noticed slight leaks around the pump so have fitted a new one but not made much difference. Looking around the system I have found something which doesn't make any sense at all. It is an open vented system (think thats the name - with a header tank in the loft).
There are 4 pipes from the boiler, 2 for the hot water for the taps and 2 x 22 mm ones for the heating. The pump is on the return. I've found a manifold underneath the floorboards upstairs with a 22mm pipe at each end and 16 x 8 mm pipes branching off.
There are 8 rads in the house and this manifold seems to supply both the feed and return for each rad which doesn't make sense to me. I can turn all the rads off except for 1 and one of the small pipes gets hot and then you can feel it returning through another which gets warm.
The fitting of these pipes to the manifold is random rather than the feeds being on one side and the returns on the other. Can any one shed any light ? At the moment I can only have a couple of rads on at a time to be effective.
