Bal.ox!! You need a 90 bend to take you from vertical to horizontal.
Puller and Newboy - Ok just clarify where you advice putting the 90 and 45 degree pipe bends:
1. Remove existing connector coming through floor and replace with this
http://www.plastics-express.co.uk/u...JigU8l_sBLDYYQx063rUaCeNozXr4-w74IaAkRI8P8HAQ so the soil pipe is now horizontal with floor.
......This will take you vertical......
2. Connect this onto the back of the WC
http://www.screwfix.com/p/mcalpine-macfit-wc-straight-pan-connector/78806
..........Good choice......
3. 45 degree bend
http://www.plastics-express.co.uk/soil-vent-systems/pushfit-soil-system/pfs-100mm?product_id=242 fitted on the the end of the WC connector to give me the angle to get across to the connector fitted in No.1
..........You may need a 90 to do that......
4. Section of soilpipe between No. 3 & 5
5. 90 degree bend
http://www.plastics-express.co.uk/soil-vent-systems/pushfit-soil-system/pfs-100mm?product_id=241 to line up with floor connector fitted in No.1
..........You need this to connect from horizontal to vertical......
