Oh no not another short courser about to enter the industry
Look mate, take the following advice very seriously and inwardly digest.
You will not be able to start up and run a business soley servicing oil boilers part time.
You will need to train to at least NVQ level 2 as a minimum in plumbing and heating, then do your OFTEC.
I am giving this advice off the back of 30 odd years experience and have/run a successful business.
My brother was in the RAF as a Avionics Tech, before also working for Brittish waste of space. I have been around many RAF stations where he worked and at Warting. I know what his job entails and I am sorry to say it is not as difficult as people are led to believe.
I mean!! you have at your disposal air publications which, tell you exactly how to do your job, test and sequence for finding faults. Most of the time you just change out the black boxes, then pop them of for repair.
You will also have someone more experienced to fall back on for advice 99% of the time. Your workload and the environment in which, you work is nothing like the field in which, you want to enter. Your environment is childsplay believe me.
You will not have this luxury self employed believe me
When a customer rings you they will expect a
timeserved tradesman with a broad knowledge of the whole trade.
Example:
Mr ........
I have a problem, my boiler won't fire!
You in your shiny new van and tools speeds out to the rescue.....
to cut it short, the oil boiler is fine, it just won't fire in CH mode. It transpires it's the synchro in the MV head that is not working, it's an old MV that the head is non swapable and therefore, the system has to be drained to change the whole valve.
This is where the valve is under the floor or in a tight cupboard somewhere. The system could be a large old open vented which, will probably air lock when trying refill.
Are you getting the drift???? By this time it's time for you to toodle off back to your real job.
At this point you have to go to the customer and ideally explain that you have done a short course and do not have the experience to complete the job.
What is she going to think?????????
CUSTOMERS DO NOT AND WILL NOT CONVENIENTLY RING WHEN YOU ARE ON DOWN TIME, DAY OFF, EVENING OR AT WEEKENDS.
Running a business is not childs play it
takes up a lot of your time and does COST money....
Training/time to do training, van, tools, and office equipment easily £8000 upwards.
Recurring costs:
Advertising Min £1000 you'll need this, this is how customers will find you!
Insurance....public £250
van £300
Stock £350
registration fee's £100 for 5 years
tool replacement £150
calibration/repair £175
accountant £500
So all in all around £3000 outlay a year and that does not cover everything, I just can't be arzed typing any more. i just put down the obvious.
People on here and the majority 95% of which are short course idiots as well, will give you advice or lead you to believe that they are successful.
Just have a look at the amount of time they spend on here and some of the stupid questions they post and think.........would a timeserved professional who runs a busy business have the time or the inclination to spend time on here??
Spend your time and training enhancing and getting on in the field which, you are in.
Don't waste thousands trying to retrain, there are many more experienced people/businesses out there who you cannot compete with. You will be no better off in the long run trying to retrain and run a business part time...YOU WILL BE WORSE OFF both finnancially and time wise.
I have given this advice in good faith, you have been WARNED!!
An NICEIC, OFTEC, Gas Safe and MCS Registered installer/business.
