The drill appears to have suffered blast damage from an "explosion" that occurred as the conductors in the cut cable were shorted together ny the drill bit.
This explosion or more accurately sustained arcing would have continued to burn until the breaker at the substation operated.
A few years ago I worked a mate's home, he had some cash in hand guy around to move/shorten the electricity supply from the middle of the house to a box at the front of the house.
I asked him what would happen if the insulation on the phases were to fail as he bent the old cable. His reply was (from memory) that if the "street box [fuse thingy]" is sufficiently far enough away, the two phases touching would just continue to go "bang, bang, bang".
They don't have a street box thingy, they are only fused back at the substation, bang, bang, bang would be a continuous massive arc, until that fuse or breaker at the SS dropped out. A very foolhardy man messing with such a cable live.
