Oil boiler not firing up
29 Jun 2006
Hello,
Did some work today on an oil heating system. Fitted two rads in a bungalow. On filling the system back up some of the rads took a while to fill, so I put heating on to get the pump running. All the rads now bled fine, and system filled ok.
However, the boiler doesn't seem to fire up when there is a call for heat. The pump runs, and there is power to the boiler, but it doen't fire.
It's a Grant oil boiler, on a pumped Y plan, 7 rads, and it's only about a two year old system.
Any ideas?
Cheers.
does the motor on the boiler start?
sounds like the overheat stat tripped if lack of water did you try reset its under the black plastic cap
