Couple of questions.
I have a nu-way boxer oil fired boiler and on a pipe running from the furnace there is a Myra unit five pump.
The top of the furnace has a metal plate which is held down with 2 butterfly nuts which do not seem to pull the metal plate tight to the furnace. The result of this is it is very noisy. What can I do to cut down this noise?
The other thing is for someone to clarify my understanding of my system.
I assume the oil comes in from the tank by gravity and then is pumped by a small pump about a foot from the entrance to the burner.
The burner ignites the oil and heats the water in a store within the furnace.
This is then brought along the pipe by pressure for a few feet and then an electric pump then forces the water around the system.
Am i barking up the right tree?
Is there usually only one pump in the system and it is normally close to the boiler?
Do heating systems like this have the ability to heat only the hot water storage tank only and not both the tank and the central heating?
If anyone can give me any insight on anything I have asked/said i would be very greatful.
Thanks.
Thanks.
