To comply with water regulations any overflow should run through a tun dish in an accessible location AND the discharge point should be protected from foul smells in the drainage system by a water trap or a fanny flap.
Ok, it's a low level cistern not a close coupled! Should be fairly straight forward to replace the flush with an internal overflow one.
Obviously you can't discharge the overflow into the basin cos it's higher!
This is another option...
