Hi we have a really old Baxi Bermuda boiler with fire:
Gas Council Numbers:
30 - 44 077 08
40 - 44 077 06
We recently moved into this house and we have plans in the next 4-5 months for knocking the place about quite considerably. The boiler to the property doesn't fire up and although it's quite obvious it needs replacing, the wall where the new one is to go isn't there yet.
The gas fire works and the piolt stays on, but the the boiler doesn't fire up. The wiring diagram shows switched power going to the stat, then through the boiler gas valve then through what appears tobe a tubular resistor (read somewhere about this being done to reduce radio interferance) back to the wiring block.
I'm not sure whether it's the resistor or the gas valve itself (how do I test if there's power to it?). In either case I guess I'd need a replacement for one of these. Does anybody know where I could get one, or indeed has one lying about? Or, failing that, can I just do away with the tubular resistor without any damage to the valve?
If I can get it to work, I will obviously not be using the boiler until a corgi registered plumber has checked the system out, but at the same time I don't want to have to pay £60-70 for someone to tell me the parts not available.
It's cold, and there's no point in getting the new combi in until the renovation work has started. Any ideas?
Any help would be much appreciated.
30 - 44 077 08
40 - 44 077 06
