Nixt said:Have you checked the HW side of the programmer is calling for heat. Also when you turn on tap does pump run? There is a flow switch on the Camray 5 yours is probably the Quartet but would have thought it has a flow switch have u checked under top cover? Theres no point changing parts until you've established why burner won't light.
hi m8 the programmer only controls the heating, nothing on there for the hot water.
and i have had the thing to bits as far as i could and could not find a flow switch. i believe it is a heat bank type without a flow switch?
