Hi, I live in an old Victorian terraced house 2bed/1bath with a 23-30y Vaillant Turbomax 242 E combi boiler that came with the house when we moved in 3 years ago.
We booked a boiler replacement through an online service for today. The new boiler is a Worcester 4000 30kw (I plan to do a loft conversion with an ensuite in the coming years, hence the 30kw).
The installer arrived this morning, looked at the boiler and noticed that the piping is 15mm. Then he checked the gas meter (installed in the cupboard under the stairs) and told me that I was f*ed with the gas pipe sizing.
He says that he could install the boiler, which probably would work, but that the piping is inadequate and that he could risk his licence if something goes wrong. And that to upgrade the piping, he would have to open/break our kitchen slate flooring and raise our living room solid wood flooring.
The piping upgrade cost is included in the agreed price, but I naively assumed that it would only require changing a section of pipe reaching the boiler, not destroying our flooring, to replace the whole pipe from the gas meter. He clearly wasn't up for the job either.
He recommended installing a 24kw Ideal boiler instead, as that could be done with the current piping and would be good enough even if we get an ensuite extra bathroom (I doubt so). I didn't want to take any uninformed decision, so I decided to hold for a couple of days, get opinions, talk with the provider and discuss the options.
We plan to reform in the oncoming years to convert the loft into a bedroom with an ensuite. We may redo the kitchen (probably changing the slate flooring then), and we would also have to change the position/size of the radiators in the living room as the current radiator is undersized, poorly placed and not enough for the room size.
Given this, I understand that the reform when moving radiators and changing the kitchen flooring would be the perfect time to upgrade the gas pipes, but this reform may happen in 1-3 years (if so).
What would be the most sensitive way to approach this?
So far, I see a few options:
A) Install a cheaper & smaller 24kw boiler that will work with 15mm piping. Upgrade the gas piping as part of the future house reform.
B) Upgrade the piping now with a new boiler (I have no idea how messy this will be, besides what the installer told me today).
C) Don't do anything at the moment, and pray for the Vaillant to keep going and replace the whole system during a reform.
D) It is 2023, time to install a heat pump instead (Very hesitant about this due to the poor insulation on the old Victorian house).
At the moment, I think A is the way to go, but I want to get second opinions before deciding, and there may be options or issues I may not have considered.
Thanks!
Thanks!
