That's probably not long enough - you have a lot to learn.romchik said:Thank you ban-all-sheds.I have about 1 month before i start on rewiring.
OK.The rewiring in a house was done about 15-20 years not sure.Each room has only 1 double sockets wich is redicualas.The sockets are in wrong places.So i decided that it will be easy to rewire than try to move old one and add some other 1or2 rings.The CU and clock are in the hall but i want to move them under stairs every wire need to be moved under stairs.That is why i decided to rewire.
But you must not, under any circumstances move the electricity meter yourself - it is not your property and you may not touch it. And if you're on a tight budget, get a quote from your electricity network operator for moving it before you do anything else - you may find you can't afford it.
Then unfortunately you aren't going to acquire the knowledge you need...unfortunately i can not read all that books.
Yes - because you must learn. You cannot undertake a task of this magnitude without knowing and understanding what to do. You cannot do it by asking questions as you go along - you might not ask the right questions. You might not ask the questions that you should. You might think you know something, and be wrong.That is why i am here and i thought that on this forum i could get help.I need to rewire only one my house and i can not learn all of it for one month.I assumed that i could asked here.But all i get is -read yourself and learn.
