any damaged or broken asbestos MUST be encasulated in a suitable sealing cement
no tin foil, no silver tape,no closure plate tape
so you could drill through the inspection cover of boiler for FGA instead of drilling through the flue if all came to all or did i pick that up all wrong?it could be vitrous enamel,failing that drill the inspection cover on the top of the boiler where you remove the baffles,or front inspection door,if you insist on drilling the flue make sure you damp it down and use a hollow diamond bit with water feed to keep the particles to a min.foil tape is best to seal the hole or a m10 bolt.
We are talking about a 1/4" hole.
You would make more dust removing the pipe for replacement.
and what happens with the vac bag?
I have fitted hundreds of asbestos flue pipes,soil pipes,gutters and down pipes.Also removed many of the same. Did I mention the water mains of which many are still in use?
This was before the wipe your a**e nanny state we now have to endure.
If basic precautions are taken the risk is miniscule.
As previously stated, more fibres would be liberated by removing the pipe!
Assuming you used a special filter as required by the HSE in the first place, you would double bag it and take it down the Council tip if they take asbestos, or you dig a big hole and drop it in the bottom.
