I've dug a hole to install a new inspection chamber for a new soil pipe i'm installing. However there's a couple of mystery pipes which are a bit in the way. One is quite close to the surface (approx 25mm) and very very rusty, the other is much deeper (approx 60mm) and doesn't look rusty so i'm assuming it could be copper or lead (i'll hae a better look in daylight!). My gas supply was recently replaced above ground and my water is a much newer plastic pipe both of which i've located so i'm assuming these are old and redundant.
Before i dare to take a saw to the old ones is there any way i can tell if they're isolated or what they were for?
