G
gaswizzard
Is this the guy that's gonna put us all out of buisness?
Went to a property where they had a radiator removed a few years ago. The isolation valves + thermostatic valve are still on the pipes and have been shut. However the pipes leading upto the valves are cold, even when the radiators are turned on. I've followed the pipes all the way upto the ceiling where they remain cold. The other rads in the house get warm.
Suggest you retrain in knitting or something even less technical if u need help with this![]()
Went to a property Does anyone have any idea why these pipes are not getting hot? Could they be cut and capped under the floorboards upstairs?
They want a new radiator fitted where the old one was removed, but i can;t figure out why the pipes are not getting warm.
Indeed , by undercutting the Bad Guys , and probably the national company with the same initialsIs this the guy that's gonna put us all out of buisness?
They want a new radiator fitted where the old one was removed, but i can;t figure out why the pipes are not getting warm.We are all allowed a Gonzo Moment when we`re learning - One of mine was not locating a hidden air vent - despite the householder saying previous bods had been in the area in question
BUT FFS 2 capped ( rad valved) pipes and no flow between them
He can only under cut the other tradesmen, if and it's a big if................. IF he knows what he's doing.![]()
On this occasion........he doesn't.![]()
Andy
Ah, Naz, that's a bit different.connected the two caps with some pipes, however their is still no flow and no hot water getting to the pipes. Neither flow or return pipe heats up.
That`s a LOT different - and similar to a poster who wanted to find which was the flow - but wouldn`t spend £15 on some pushfit pipe and fittings for a temporary loopAh, Naz, that's a bit different.connected the two caps with some pipes, however their is still no flow and no hot water getting to the pipes. Neither flow or return pipe heats up.
C.
C.AND they accused me of Taking the P.
Nadz - try pushing the pin under the TRV head - don`t pull it out
Then shut all the rads leaving just your temporary loop open ..
Nige's point is an obvious one - which I missed![]()
